![]() | Home > General > New engine: timing belt: recommendation |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 222 ![]() ![]() ![]() |
For the cost they charged i would have expected the head to be removed and inspected, this would then need to be stripped and skimmed before replacement which would involve removing and replacing the valves. Do you have an invoice showing what parts they supplied, that would give us a clue as to what the works involved.
Here's some links that maybe helpful: -
RRSJRM Member Since: 13 Feb 2016 Location: UK Posts: 24 ![]() |
Those diagrams are very helpful.
Got the car back. Definitely not the injector. I spoke to the guy returning the car on his flat bed and they sprayed the injectors while he was there to check for leaks.
More than happy to offer advice, just a shame it wasn't the outcome we hoped for. When you advertise it, be sure to list what was done and the diagnosis now as if it's only a dropped valve it's an easy fix for someone, it's going to be a much more attractive buy to someone than dealing with a snapped crank!
Sadly I can't post to the Forum. I fall shy of the 25 post rule for that sub-forum and I can't stick it on the eBay forum because it is my own product I would be promoting.
Meshan Member Since: 19 Oct 2024 Location: Northampton Posts: 85 ![]() ![]() ![]() |
Your only 8 posts away L320 Range Rover Sport 2008
6 now 😉
Woops, I just made a bid on a broken sport, fat finger syndrome. Maybe that'll help it along a bit |
I must have had at least a dozen people ask to buy it outright in the first 12hrs of listing. Seems there is more of a market for these things than I anticipated.
That's because it's an easy fix!!!! |
It's bittersweet but the car has now past it's reserve and will sell. Assuming the buyer turns up etc. this thread is now but a week away from conclusion. |
