![]() | Home > Technical > Messed up intake manifold replacement job |
dhallworth Member Since: 14 Aug 2015 Location: Glasgow Posts: 50 ![]() ![]() |
Smoke coming from down that side of the engine is quite normal after that job as there will be oil that drips down onto the manifold/turbo when you take the cover off. It should clear after a few miles.
palawandiving Member Since: 02 Mar 2025 Location: chipping norton Posts: 3 ![]() ![]() ![]() |
Hi thanks for your reply, I think the actuator is ok, the plastic thing is intact and the actuator moves backwards and forwards. The rest of the EGR valve I am not sure about where it bolts onto the side of the engine... |
