Home > Faults & Fixes > L320 Dash Cover - Does It Fit
Meshan
2008 pre-facelift L320
My dashboard top is starting to split around the passenger airbag.
Looking at options to fix, or replace.
Does the facelift dash fit, or is it completely different?
Has anyone changed theirs? L320 Range Rover Sport 2008
3.6 TDV8
Remap
EGR Blank
Post #647912 Fri May 09 2025 10:27am
Meshan
Ignore that post, I just looked at the 2 and they seem quite different L320 Range Rover Sport 2008
3.6 TDV8
Remap
EGR Blank
Post #647913 Fri May 09 2025 10:30am
Timmo1710
2010 Range Rover Sport TDV8 Autobiography Santorini Black
It does fit but you have to change a lot of parts, I did this to my old 2008 L320.
Happy to help if need be 👍
Post #648438 Thu Jun 19 2025 12:35am
Meshan
What parts do you have to change?
There are a lot more facelift dshboard on ebay L320 Range Rover Sport 2008
3.6 TDV8
Remap
EGR Blank
Post #648439 Thu Jun 19 2025 6:49am
Timmo1710
There was literally nothing information wise out there so I had to do a bit of trial and error.
I never got around to completely finishing it due to selling the car.
Essentially you need:-
Top dash part
Instrument cluster surround inner and outer
Centre console
Gear selector surround which the connectors plug in straight swap.
The terrain response controls needs the old circuit board putting in the new one if that makes sense.
Parking brake switch swaps over.
Fridge also swaps over
The side panels of the centre console are different
There’s also a centre panel that’s different to where the climate control and other bits are (can get you a picture)
Original stereo needs stripping down so it’s just the radio part and hiding
Screen swapping over with connector
Clock and lights wiring up - the buttons for menu etc will not work.
The air vents
Gearstick and surround - can swap the green part for release the shifter as one is longer than the other.
Top glove box needs swapping over and The only issue I haven’t worked out yet is the light switch as it’s worked differently. I’ve hidden the old one and set it on auto for now.
Post #648444 Thu Jun 19 2025 10:33pm
Meshan
I may continue with the split in the dash.
Or keep trying to find an original in good condition. L320 Range Rover Sport 2008
3.6 TDV8
Remap
EGR Blank
Post #648447 Fri Jun 20 2025 8:34am
