![]() | Home > General (L494) > Delay pulling away - Trans remap? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
Can't really say on a L494, but when I bought my L320 5.0L s/c many years ago it did take me while to get used to throttle response, after being used to a oil burner (TDV8) and having to give the pedal a reasonable push to respond, driving the s/c the same it took of like a rocket with the front passenger nearly ending up in the rear seat, so had to learn to be a little more easy with the pedal, however if I was a bit to cautious it could give the feel of a delay when pulling away, used to it now after all this time so it's no issue, probably not your issue just my own personal experience when first having the car, a throttle response delay is certainly something the 5.0L does not suffer from normally unless there is a fault of some kind.
T Member Since: 18 Feb 2024 Location: Isle of Wight Posts: 103 ![]() ![]() ![]() |
Have you seen this thread?: https://www.rrsport.co.uk/forum/topic62637.html
Alipapa Member Since: 18 Jan 2018 Location: Hong Kong Posts: 11 ![]() |
Mine is also a 5.0 SC and encounter this problem since day1. (Have the car since 2018)
