Home > General (L461) > D350 D300 Battery drain
Neilm
If left unused my battery is draining quickly I wonder if other owners have experienced the same? Leaving the car locked with a fully charged battery it's at 13.1v day 1, by day 7 12.5v, after 10 days below 12v and shortly after unable to start.
Has anyone found the same? A standard Autobiography D350 other than a Starline i96. I've used the same alarm on multiple vehicles and they last for weeks. Perhaps the alarm is keeping other systems awake, there is a vehicle fault, or that they are all shockingly bad?
Would like to know from other owners before disconnecting/removing the alarm and fault finding, thanks ๐Ÿ‘
Post #647621 Tue Apr 08 2025 10:41pm
jimbg
Not normal, disconnect the alarm and see if that fixes it. 2026 P460e Autobiography on order
2022 HSE Dynamic P400e
2006 HSE
Post #647625 Wed Apr 09 2025 9:54am
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Left mine for weeks and no problem starting
Post #647635 Wed Apr 09 2025 9:51pm
Neilm
Thanks for the responses.
Finally had chance to look at this, nothing to do with the alarm unfortunately. Starline draws just 50 mA, vehicle drops to around this after 2 minutes and then after 5 minutes (tested multiple times) steps up to 0.6 amps.
I don't have much faith in a dealer sorting this ๐Ÿ˜ช
Post #647705 Thu Apr 17 2025 8:19pm
jimbg
Were those measurements with the alarm disconnected?
If not the alarm could be waking something up? 2026 P460e Autobiography on order
2006 HSE
Post #647706 Thu Apr 17 2025 9:24pm
Neilm
Yes completely disconnected and unplugged. Alarm connected or not at exactly 5 minutes after locking something wakes up and constantly draws 0.5 amps. Surprised the battery lasts 10 days but don't know the battery capacity.
Would be interesting to see if another one is the same.
Post #647707 Thu Apr 17 2025 9:30pm
JDPRRSUK
Just a thought - you havenโ€™t had a recent software update that coincided with problem? LR Assist told me they if an update doesnโ€™t fully complete, you get a battery drain as it keeps trying to pull the new data down but repeatedly fails. Mine went completely flat eventually and needed to call them out.
Post #648002 Fri May 16 2025 7:52am
Claud
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
I had the same issue on my P440E, it was identified by Land Rover Assist as a faulty Battery Energy Control Module (BECM). Software update fixed the issue. The Mild hybrids likely have a similar module. RRS Autobiography P460E
Post #648026 Sat May 17 2025 10:45am
Neilm
Thanks for your suggestions. It is booked in the dealership 5th June. I do hope it's as simple as a software update ๐Ÿ‘
Post #648028 Sat May 17 2025 8:47pm
jimbg
You could always call LR Assist when its flat and they can probably fix it at home? 2026 P460e Autobiography on order
2006 HSE
Post #648029 Sat May 17 2025 9:04pm
Neilm
Would they update the software or just jump the battery to start it?
Post #648030 Sat May 17 2025 9:11pm
Claud
In my case they jump started the car and then did a full fault code scan, identified the issue with the BECM and updated the software. RRS Autobiography P460E
Post #648031 Sat May 17 2025 9:17pm
Neilm
Thanks, I'll give it a try and let it go flat. May save a waste of a day going to the dealership ๐Ÿ‘
Post #648032 Sat May 17 2025 9:20pm
jimbg
They are very experienced at fault finding and will either fix it or let your dealer know what is necessary.
The guy who came out to me ordered some bits and came back the next day. 2026 P460e Autobiography on order
2006 HSE
Post #648033 Sat May 17 2025 9:28pm
Neilm
It didn't take long to go flat again, with security phoning today due to battery voltage. I phoned LR assist and this afternoon they updated most modules. It appears that both headlamp modules were the cause and not powering down. Time will tell, I'll report back in a few days if it's resolved. Thanks for the advice ๐Ÿ‘
Post #648049 Mon May 19 2025 5:58pm
