![]() | Home > Technical > DPF sensor. |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 225 ![]() ![]() ![]() |
Could be a split hose between the differential pressure sensor and the DPF, have a look underneath, the sensor is on a bracket right by where the propshaft mates to the gearbox output flange, just follow the pipes down checking for cracks or splits. |
LesW Member Since: 30 Oct 2021 Location: Pays de la Loire Posts: 92 ![]() ![]() |
I suppose it's possible that a pipe could have inadvertently been knocked during the work, one of the jobs was new transfer box oil, although I'm not sure if that's close to the sensor. I'll have a look tomorrow. Cheers. A Cheshire expat in France.
I did the job today and fitted the new sensor, as well as a pipe that I managed to split taking it off.
RRS? Member Since: 02 Sep 2023 Location: Lincs Posts: 36 ![]() ![]() |
Hi, I’ve the same issue as you had.
Hi Pete.
Thanks Les,
Yes, that's the one.
Hi Les,
No, nothing to do afterwards, it just works.
