![]() | Home > General > Does the 2.7.... |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5154
I do believe they have some sort of crankcase ventilation oil separator which has a diaphragm in it, not sure what symptoms that would produce if it was split by any chance though, as said only a thought as wouldn't know for sure.
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
Or it could be valve stem leakage, or some other issue. Assuming it's the 2008 in your profile, it's 17-18 years old and stuff wears. 2012 SDV6 - it's missing a couple of cylinders
| Toonraider Member Since: 15 May 2022 Location: Newcastle upon Tyne Posts: 117
Yeah, aged stuff wears...just like me. Just sporadic 8nitial smoke on start up. If it was stems I imagine under boost etc it would show too, but nothing. That's why I imagine ccv. |
| Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 472
When the temperature drops the system increases fuel to help it start. Thats the source of your smoke . The 2.7 is a bit overgenerous to the point when it floods the engine and wont start and you have to pour hot water over the temp sensor in the top right hand hose to get it to start. ( making it think its hotter than it is )
I have remote controlled pre heater system to combat that. I thought unburned fuel was more white ish.
