![]() | Home > Technical > Which compressor??? |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961 ![]() ![]() ![]() |
The original compressor would most likely have been Hitachi,, still available I believe but a lot of people fit AMK compressors as at one point were easier to get hold of. They are a better unit but a little more expensive compared to Hitachi and also require a software update in order to function at their best. 2010 RRS, TDV8
andyfid Member Since: 27 Jan 2025 Location: Barnsley Posts: 9 ![]() ![]() ![]() |
So the AMK will still function ok without the update |
Meshan Member Since: 19 Oct 2024 Location: Northampton Posts: 96 ![]() ![]() ![]() |
I have the same car
L320 Range Rover Sport 2008
Why would you want to fit the more expensive AMK unit if you are not going to install it correctly. I don't know if it would function satisfactory without the software upgrade. You may as well stick with Hitachi as it's1 a straight swap. 2010 RRS, TDV8
Just ment until I can get it in for updating as I take it it’s only done by rangerover dealers or can it be done via IID TOOL |
Ahh, I see,, I did read somewhere that someone had fitted one and it worked but it was only half a story so to speak. Not sure it's dealer only upgrade, a competent indie should be able to sort it out. 2010 RRS, TDV8
