Home > Technical > Which compressor???
andyfid
United Kingdom 2008 Range Rover Sport TDV8 Autobiography Bonatti Grey
Which compressor???
Hi guys could do with a bit of help just bought a L320 3.6 v8 2008 the previous owner looks to have fitted a cheap Chinese compressor and it’s throwing up faults and I want to put a genuine one back on but which one do I need does anyone know please then I can have a look on eBay
Post #646954 Mon Feb 17 2025 6:26pm
gogsy1956
The original compressor would most likely have been Hitachi,, still available I believe but a lot of people fit AMK compressors as at one point were easier to get hold of. They are a better unit but a little more expensive compared to Hitachi and also require a software update in order to function at their best. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #646956 Mon Feb 17 2025 8:16pm
andyfid
So the AMK will still function ok without the update
Post #646963 Tue Feb 18 2025 4:59am
Meshan
I have the same car
I bought this and it works fine.
https://www.autodoc.co.uk/hitachi/13965231
Easy swap.
The price fluctuates daily. Once it hit £350 I bought and it came a few days later.
Also bought this which was needed.
https://www.ebay.co.uk/itm/313508686131
Also bought a new bracket and painted in hammerite.
Mine was falling apart.
https://maltings4x4store.co.uk/compressors...rqu500064/
Replaced all nuts and bolts using Advanced Factors.
You also need a new relay. The autodoc compressor came with one.
The hardest part is getting the top cover off and on.
Then plenty of grease and contact cleaner.
Also, save your rubber bushings from the bracket and use Liquid Molly Rubber protector.
Works fine now. L320 Range Rover Sport 2008
3.6 TDV8
Remap
EGR Blank
Post #646967 Tue Feb 18 2025 10:26am
Meshan
3.6 TDV8
Remap
EGR Blank
Post #646968 Tue Feb 18 2025 10:27am
gogsy1956
Why would you want to fit the more expensive AMK unit if you are not going to install it correctly. I don't know if it would function satisfactory without the software upgrade. You may as well stick with Hitachi as it's1 a straight swap. 2010 RRS, TDV8
22" overfinch
Post #646970 Tue Feb 18 2025 5:57pm
andyfid
Just ment until I can get it in for updating as I take it it’s only done by rangerover dealers or can it be done via IID TOOL
Post #646983 Wed Feb 19 2025 7:24pm
gogsy1956
Ahh, I see,, I did read somewhere that someone had fitted one and it worked but it was only half a story so to speak. Not sure it's dealer only upgrade, a competent indie should be able to sort it out. 2010 RRS, TDV8
22" overfinch
Post #646987 Wed Feb 19 2025 8:30pm
