![]() | Home > Faults & Fixes > ACE Yellow Fault |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5122 ![]() ![]() ![]() |
no pics
DovFox Member Since: 12 Jan 2025 Location: Caerphilly Posts: 9 ![]() ![]() ![]() |
My bad...added 👍 |
RR garage said it's likely to be diesel overflow |
Took the side under tray off and found the problem, pipe corroded at the front end. Now, RR garage quoted £2k to replace entire front ACE section. The rest of the pipes are completely fine and only need a small section replaced.
I don't think many ppl are working on that age car.
The gent who engineers the pipes has videos on how to do it too, so should be straight forward - will keep people updated. This could potentially save me £1.9k! |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4526 ![]() ![]() ![]() |
£144 for that? |
What’s the price and availability of oem |
RR said anywhere between £500-600 for either front or rear set of pipes. Would have to be put on a back order, waiting time anywhere between 2-3 months 😳😅
It's maybe different for us up here. If the pipes have rotted through there, they're pretty well |
All fixed. No more leaks. Was straight forward, used pipe cutter to trim to size. The kit came with compression fittings. Had to bleed the system through rear bleed points - just awaiting calibration and should be good to go 👌
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 313 ![]() |
Hi had the same issue myself and used the same pipe from ebay.
Yes, took it to RR garage to have it calibrated and new fluid flushed through. If you had the car running dry at all it's likely that the block is knackered. It's the one that the new pipe you installed goes to. Or it could sensor issues within the bloc.
Hey thanks for the reply.
