![]() | Home > Faults & Fixes > ACE Yellow Fault |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5042 ![]() ![]() ![]() |
no pics
DovFox Member Since: 12 Jan 2025 Location: Caerphilly Posts: 7 ![]() ![]() ![]() |
My bad...added 👍 |
RR garage said it's likely to be diesel overflow |
Took the side under tray off and found the problem, pipe corroded at the front end. Now, RR garage quoted £2k to replace entire front ACE section. The rest of the pipes are completely fine and only need a small section replaced.
I don't think many ppl are working on that age car.
The gent who engineers the pipes has videos on how to do it too, so should be straight forward - will keep people updated. This could potentially save me £1.9k! |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4462 ![]() ![]() ![]() |
£144 for that? |
What’s the price and availability of oem |
RR said anywhere between £500-600 for either front or rear set of pipes. Would have to be put on a back order, waiting time anywhere between 2-3 months 😳😅
It's maybe different for us up here. If the pipes have rotted through there, they're pretty well |
All fixed. No more leaks. Was straight forward, used pipe cutter to trim to size. The kit came with compression fittings. Had to bleed the system through rear bleed points - just awaiting calibration and should be good to go 👌
