![]() | Home > General > Kind of stupid this |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5154
I assume you have the adjustable steering column fully retracted to the dash, slightly taller than you and never had a issue.
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5138
Only issue I have is when the rear seats are folded down flat. Little room then |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9156
I'm 6ft and don't have a problem. Maybe check the runners for something blocking the motion. Also, as Col suggests, is the wheel retracted towards the dash? That has a good bit of movement in it. 2012 SDV6 - it's missing a couple of cylinders
| Axl Member Since: 20 Nov 2024 Location: Ayr Posts: 73
Yes the wheel's in a far as it'll go, it's probably me I just like to stretch my legs. |
I have long legs. and even I don't have the seat all the way back.
I think it's the same but will check later. It's just odd that in the l322 i was fine as i said above but not in this. |
| peterjj Member Since: 15 Mar 2017 Location: Canberra Posts: 49
Have you tried a lot more seat height and adjust the tilt to suit? Pete
Yes I've got it at the highest but won't go back far enough. |
| Cpt Jack Sparrow Member Since: 07 Sep 2016 Location: Cardiff Posts: 182
Sound like some thing is not right. I have a 2013 L320 and I'm 6' 1" with loads of leg space and seat nowhere near fully back.
Probably is but don't know where as I've not liked yet, hopefully later today. If that's the way it is with this though (stupid as i sounds) I'll either go back to an l322 or stick to an ordinary car. |
they are better than ordinary cars, as in those your legs would be out stretched.
| Clint t Member Since: 11 Jun 2023 Location: Somerset, uk Posts: 4
If you lower the seat it drops down and back giving a fair bit of extra space. I'm 6'3" and built like a brick sh...... you get the idea but still have room. |
I did that but like sitting high or I would, i could be high and further back in the l322 but not this. |
| Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 479
With the back seats flat for luggage yes you are restricted with how far back the driver and passenger seats will go due to the back seats being in the way, if you have the same issue with seats all in the upright position then there is an issue... =========================================== 2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar, |
| All times are GMT |
