Home > General > Kind of stupid this
Axl
2010 Range Rover Sport TDV8 HSE Adriatic Blue
Kind of stupid this
But on the 09 sport I can't get the seat back far enough to stretch my legs. With it as far back as it'll go I'm still to close to the wheel.
When I had the l322 a few years ago I was fine in it but not this. I'm wondering if there's something jammed in the runners (haven't looked) or if it's the way they are.
I'm not tall ie about 5 10 but like to sit quite far back and can't in this.
Is there anything I can do.
Post #645977 Mon Dec 30 2024 1:26am
I assume you have the adjustable steering column fully retracted to the dash, slightly taller than you and never had a issue.
Post #645978 Mon Dec 30 2024 7:19am
Only issue I have is when the rear seats are folded down flat. Little room then
Post #645979 Mon Dec 30 2024 7:29am
I'm 6ft and don't have a problem. Maybe check the runners for something blocking the motion. Also, as Col suggests, is the wheel retracted towards the dash? That has a good bit of movement in it. 2012 SDV6 - it's missing a couple of cylinders
Post #645982 Mon Dec 30 2024 12:01pm
Axl
Yes the wheel's in a far as it'll go, it's probably me I just like to stretch my legs.
Post #645983 Mon Dec 30 2024 12:05pm
I have long legs. and even I don't have the seat all the way back.
Obvious thing is to check the driver and passenger seats go back the same amount, by checking if they line up in the rear.
I'm thinking its a facelift thing
Post #645984 Mon Dec 30 2024 12:10pm
Axl
I think it's the same but will check later. It's just odd that in the l322 i was fine as i said above but not in this.
Post #645985 Mon Dec 30 2024 12:19pm
peterjj
Australia
Have you tried a lot more seat height and adjust the tilt to suit? Pete
2008 L320 TDV8
2022 Hilux Rugged-X
Post #646007 Mon Dec 30 2024 11:00pm
Axl
Yes I've got it at the highest but won't go back far enough.
Post #646009 Tue Dec 31 2024 12:11am
Cpt Jack Sparrow
Wales 2013 Range Rover Sport SDV6 HSE Fuji White
Sound like some thing is not right. I have a 2013 L320 and I'm 6' 1" with loads of leg space and seat nowhere near fully back.
As said above how does it compare to the passenger seat movement.
CJS
Post #646011 Tue Dec 31 2024 9:26am
Axl
Probably is but don't know where as I've not liked yet, hopefully later today. If that's the way it is with this though (stupid as i sounds) I'll either go back to an l322 or stick to an ordinary car.
Post #646013 Tue Dec 31 2024 12:07pm
they are better than ordinary cars, as in those your legs would be out stretched.
As your legs have to dangle down in a RR (knee at right angle), it gives loads more room for legs
Post #646015 Tue Dec 31 2024 1:56pm
Clint t
If you lower the seat it drops down and back giving a fair bit of extra space. I'm 6'3" and built like a brick sh...... you get the idea but still have room.
Post #646019 Tue Dec 31 2024 5:18pm
Axl
I did that but like sitting high or I would, i could be high and further back in the l322 but not this.
Post #646021 Tue Dec 31 2024 6:04pm
Autobiography1969
With the back seats flat for luggage yes you are restricted with how far
back the driver and passenger seats will go due to the back seats being
in the way, if you have the same issue with seats all in the upright position
then there is an issue... ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #646025 Tue Dec 31 2024 10:16pm
