![]() | Home > Maintenance & Modifications > ACE removal |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5116 ![]() ![]() ![]() |
has been discussed before
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 463 ![]() ![]() ![]() |
The obvious question is why?
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9112 ![]() ![]() ![]() |
It's a 6 month old post from someone who only posted it and hasn't posted since, so it's unlikely they're still here. (Or they are doing a cracking lurking job! |
Oops. I’m sure someone asked recently. |
These have been welded up before ......Remove pump ...shorter belt EPLS Always listen to old people or when they die you will live on in ignorance.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4517 ![]() ![]() ![]() |
It's more expensive to remove the system than to replace a leaking bar as a 1 off job Long term, it's much cheaper than (eventually) replacing both bars, front + rear pipes and a valve block ![]() |
I'm on my second RRS, both of which had dynamic response anti-roll bars fitted. One was sold at 175k miles and the other is currently at 155k miles. I have replaced a grand total of one rear anti-roll bar and that was on the first RRS and it was done under LR warranty.
My front dampers are getting ready for replacement. They're the active ones. I think I'll save money by fitting some scaffold tubes instead. |
Maybe you were just lucky |
LR giving a |
rayodunne Member Since: 17 May 2018 Location: Sudbury Posts: 41 ![]() ![]() ![]() |
You could buy these or similar from hydraulic shop and build the sections yourself.
