![]() | Home > General > ACE Pipes LR015144 |
JAMO1282 Member Since: 18 Jan 2024 Location: Cumbria Posts: 23 ![]() ![]() ![]() |
Can you not just do the repair yourself mate? It's honestly not a hard job although easier if you can get the car up a height on a lift. You just need to cut the damaged section out with a small dremel cutting wheel, clean the pipe up a little so the new connections get a good seal then fit the replacement pipe and connectors/compression fittings. |
Flinders Member Since: 12 Dec 2014 Location: West Yorkshire Posts: 126 ![]() ![]() ![]() |
Jamo1282, thank you but I’m female and have no idea what to do! Don’t even know how to get to the leaky bit! |
Get the overalls on lol. Sorry I can't be of more help. All you need is someone who likes tinkering with cars (a friend maybe)and show them the fix I did which I got off another member on here and away you go. |
Haha! Honestly I would not know where to start! 🤣🤣🤣 |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4500 ![]() ![]() ![]() |
RQA500120 is a direct replacement (and cheaper |
Thanks Disco_mikey |
MadAnt Member Since: 12 Nov 2023 Location: West Sussex Posts: 2 ![]() ![]() ![]() |
Hi to all on the thread
Well we have finally received our LR015144 part! 7 months of waiting! Just need to get the part fitted now so fingers cross the big ‘ole gal gets back on the road soon! |
We had an RQA500120 turn up 2 days ago
Do you know if the RQA500120 part number will fit a late model L320 (2012) SDV6?
Well we have a right dilemma! Great that the part is here but not so great that the garage have now advised us due to body off and risks of other parts failing the repair could cost us between £4000 to £5000! So at best we have cost of £1500 if all goes well and it doesn’t need valves and rear pipes too and at worst £5000 (and the rest!) and that’s as long as everything else works as it’s been stood for 7 months doing nothing! |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5090 ![]() ![]() ![]() |
I don't know for certain as have not ever done the job, but going by other members post's on the subject it can be done with a slight body lift, personally I think the garage is covering their own a**e if they screw up, and shafting you or don't actually want the job.
Not a body off job |
Yes, pipework is identical ![]() |
