Home > General > ACE Pipes LR015144
Flinders
England 2012 Range Rover Sport SDV6 HSE Sumatra Black
ACE Pipes LR015144
We are still trying to get our RRS MY2011 fixed as it’s been off-road since October 2023 awaiting LR part LR015144 Big Cry .
Getting nowhere with LR customer relations despite ordering on critical and raising a complaint. The dealer we have ordered through had 15 on back order before us at the beginning, we are now down to 11 before us as a couple have dropped off the list.
Tried to get someone to fit the Pirtek repair as Jamo has done on here but no one will do this for us, so now looking at the RQA500120 part. Although these don’t seem to be in stock either but if they were are these a direct part for the LR015144?
Is there anywhere, up North, where we could get our car fixed, even if the pirtek part repair, just to get us going? We are in West Yorkshire but could get her towed to be repaired.
Any advice on where we can buy parts in stock or tips to get the part sooner would be greatly appreciated! It’s not good for the old girl to be sat not moving for so long Big Cry
Post #640473 Sun Mar 17 2024 2:01pm
JAMO1282
England 2011 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Can you not just do the repair yourself mate? It's honestly not a hard job although easier if you can get the car up a height on a lift. You just need to cut the damaged section out with a small dremel cutting wheel, clean the pipe up a little so the new connections get a good seal then fit the replacement pipe and connectors/compression fittings.
Post #640475 Sun Mar 17 2024 2:11pm
Flinders
Jamo1282, thank you but I’m female and have no idea what to do! Don’t even know how to get to the leaky bit! Whistle Very Happy
Post #640476 Sun Mar 17 2024 2:40pm
JAMO1282
Get the overalls on lol. Sorry I can't be of more help. All you need is someone who likes tinkering with cars (a friend maybe)and show them the fix I did which I got off another member on here and away you go.
Post #640477 Sun Mar 17 2024 2:48pm
Flinders
Haha! Honestly I would not know where to start! 🤣🤣🤣
Post #640478 Sun Mar 17 2024 3:46pm
Disco_Mikey
RQA500120 is a direct replacement (and cheaper Confused) than LR015144
We've 3 sets of each on order for whatever comes in first
Post #640479 Sun Mar 17 2024 3:52pm
Flinders
Thanks Disco_mikey Thumbs Up
Where’s the best place to order the RQA500120 from? I’ll keep the order in at the dealers and take whichever comes first!
Post #640483 Sun Mar 17 2024 8:36pm
MadAnt
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Java Black
Hi to all on the thread
First post and I'm stuck in the same boat regarding sourcing front ACE pipes for my 2012 RRS.
Harwoods Chichester my nearest RR dealer has 4 on a waiting list since January this year, and no updates from Land Rover as to when these back orders will be fulfilled.
I was hoping to get a set as the body is coming off soon for a few jobs, and wanted to get these swapped out at the same time.
Looks like I'm just going to have to sit it out, and fit once available using the partial lift method mentioned don here elsewhere.
Extensive Google search has drawn a blank also......
Post #640741 Wed Mar 27 2024 10:40am
Flinders
Well we have finally received our LR015144 part! 7 months of waiting! Just need to get the part fitted now so fingers cross the big ‘ole gal gets back on the road soon!
Post #641134 Thu Apr 11 2024 10:24pm
Disco_Mikey
We had an RQA500120 turn up 2 days ago
Still no sign of the LR015144, but at least we'll get the car done and gone, and a spare set in stock when they do turn up
EDIT: Both ordered at the same time Wink
Post #641136 Fri Apr 12 2024 7:59am
MadAnt
Do you know if the RQA500120 part number will fit a late model L320 (2012) SDV6?
Many thanks
Post #641139 Fri Apr 12 2024 9:26am
Flinders
Well we have a right dilemma! Great that the part is here but not so great that the garage have now advised us due to body off and risks of other parts failing the repair could cost us between £4000 to £5000! So at best we have cost of £1500 if all goes well and it doesn’t need valves and rear pipes too and at worst £5000 (and the rest!) and that’s as long as everything else works as it’s been stood for 7 months doing nothing! Big Cry
The car is probably only worth £5000 if that, so the thought of spending more than it’s worth to repair as we are looking to sell it anyway seems madness. Been told the scrap value is £386! Is there anywhere that will take it for parts or where we can advertise for parts and get more money for it?
Those of you who have had the arc pipes replaced how much did you pay? Did you also have to have the valves replaced? Was it a full body off? Direct message me if you don’t want to put costs etc on here. Just looking for any other options or if the risk is worth it to repair. Question Banging Head Thanks everyone.
Post #641156 Fri Apr 12 2024 8:57pm
I don't know for certain as have not ever done the job, but going by other members post's on the subject it can be done with a slight body lift, personally I think the garage is covering their own a**e if they screw up, and shafting you or don't actually want the job.
Post #641157 Fri Apr 12 2024 9:23pm
Disco_Mikey
Not a body off job Thumbs Up
Never failed to get the corroded/seized pipework out the valve block
Not sure what to make of that TBH...
Post #641158 Fri Apr 12 2024 10:08pm
Disco_Mikey
Many thanks
Yes, pipework is identical Thumbs Up
Post #641159 Fri Apr 12 2024 10:08pm
