![]() | Home > General > My new to me 2006 supercharged fixes and faults. |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 352 ![]() ![]() ![]() |
Lower steering column day today as I still wasn't happy with how it felt driving, usual light feeling and sometimes off centre steering wheel in a straight line and sometimes perfectly straight. Thought it went heavy last week for a second or 2.
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 432 ![]() ![]() |
Got my paint to correct at some point. Some bumper scuffs to blend in, then it’s out with the wet sanding and Hex-Logic pads. First job is taking off the tatty old side steps and fitting some nicely prepped sill covers. My 4.2 doesn’t have privacy glass, which initially I wished it had, but the more Rangeys I see, incl FF without it, makes me realise how much classier it looks. The side step elimination also makes for much nicer profile. |
I was pleased with the paint correction I did on my mates porche the clear coat and paint on those things is far superior than on the sport.
Spring/summer is on the way so it's time to turn my attention to body work. It's been a while since I waved a spray gun around so I invested in colour matched rattle cans off the bay and picked up an old sc front grill.
A couple of things that have bugged me got sorted today. The rear hatch button was grey, as was the rear bumper tread plate, so whizzed them both off/out and treated them to some bumper black restorer stuff.
Yes it just pulls off but get some new clips just incase. Iv got a new sport/sc badge sitting here and new chrome Button and surround. BUT iv paint to sort bottom right hand corner just about the lower trim panel. It's getting the colour code treatment but I'm leaving off the RANGE ROVER |
Where do you get your clips ? Wouldn’t know where to start looking to ensure I got the correct ones.
Get them from evil bay I buy them by the 20 |
Fitted the grill luckily I had a spare badge in stock need to black out the RANGE ROVER on the bonnet.
83series3 Member Since: 19 Sep 2021 Location: South East Kent Posts: 50 ![]() ![]() ![]() |
Making great progress there. I’ve spent another frustrating day with the Dynamic Response troubleshooting …. I’ve put all the original solenoids back on, as it was instantly failing with the replacement solenoid (the one on the back of the valve block) …. So now I’m back to the system failing on left hand turns …. |
Have you been turning off the traction control when leaving the house ? |
Iv got traction control ? |
Been researching these and think I’m going to go with the G900 Pro version. There’s £70 off via Wolfbox direct at the mo. Just need to work out if I can remove the existing rear view mirror and fit it with the optional mounting bracket, which should make it a lot neater. The wires should also hopefully tuck into the 2 piece plastic shroud that covers the existing mounting arm. Some investigation needed but will report back in n due course. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5116 ![]() ![]() ![]() |
The existing cover, covers the rain sensor. |
