| RRSPORT.CO.UK | ||
|  | Home > General > Service Required Message |
| NoExpert Member Since: 28 Jan 2022 Location: PoznaÅ, Poland Posts: 524      | Itās the oil change reminder and needs to be reset with diagnostics, regardless of what others may say. There are two different things to reset, service timer and oil life. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
|  Mon Feb 12 2024 7:41pm |
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167      | Eh up No Expert š
|  Mon Feb 12 2024 7:50pm |
| NoExpert Member Since: 28 Jan 2022 Location: PoznaÅ, Poland Posts: 524      | Itās based on mileage and/or oil dilution (calculated by DPF regens). This is why two different things need to be reset.
|  Mon Feb 12 2024 7:53pm |
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167      | Eh up no expert
|  Mon Feb 12 2024 8:21pm |
| Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251      | https://www.rrsport.co.uk/forum/topic54933.html
|  Mon Feb 12 2024 9:00pm |
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167      | Eh up stevepd
|  Mon Feb 12 2024 9:04pm |
| NoExpert Member Since: 28 Jan 2022 Location: PoznaÅ, Poland Posts: 524      | Only 2000 miles, they didnāt reset it. Possibly didnāt reset it the time before either. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
|  Wed Feb 14 2024 4:45pm |
|  Wed Feb 14 2024 8:18pm |
| NoExpert Member Since: 28 Jan 2022 Location: PoznaÅ, Poland Posts: 524      | Correct, extraction tube is about the same height as the drain plug so you get nearly everything out of it.
|  Thu Feb 15 2024 10:42am |
|  Thu Feb 15 2024 8:19pm |
| Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 331  | Sounds either DPF is getting clogged up so you need to drive it above 50mph for about 20-30 mins at above 2000rpm to clear it.
|  Fri Feb 16 2024 12:46pm |
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167      | Ehup Karlp606
|  Fri Feb 16 2024 7:26pm |
| Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 331  | Get a cheap code reader from Amazon - next day delivery and it will help you if thereās a code stored | ||
|  Fri Feb 16 2024 8:52pm |
| Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 331  | Iāve got a code reader but based just outside of Hull matey | ||
|  Fri Feb 16 2024 8:53pm |
| Posting Rules
