![]() | Home > General > Service Required Message |
| NoExpert Member Since: 28 Jan 2022 Location: PoznaÅ, Poland Posts: 522
Itās the oil change reminder and needs to be reset with diagnostics, regardless of what others may say. There are two different things to reset, service timer and oil life. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167
Eh up No Expert š
Itās based on mileage and/or oil dilution (calculated by DPF regens). This is why two different things need to be reset.
Eh up no expert
| Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251
https://www.rrsport.co.uk/forum/topic54933.html
Eh up stevepd
Only 2000 miles, they didnāt reset it. Possibly didnāt reset it the time before either. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Eh up No Expert š
Correct, extraction tube is about the same height as the drain plug so you get nearly everything out of it.
Eh up
| Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 331 |
Sounds either DPF is getting clogged up so you need to drive it above 50mph for about 20-30 mins at above 2000rpm to clear it.
Ehup Karlp606
Get a cheap code reader from Amazon - next day delivery and it will help you if thereās a code stored |
Iāve got a code reader but based just outside of Hull matey |
| All times are GMT |
