![]() | Home > Technical > Reason for Crankshaft breakages and how to avoid. |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 447 ![]() ![]() ![]() |
The crankshaft breaks due to bearing shells "wrapping" ie moving over one another and jambing the crankshaft. Now these shells cannot wrap unless they approach half original thickness as there would be no room for them to move over one another.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4497 ![]() ![]() ![]() |
Its incredible that people will take anything written/brodcast on Facetube as gospel, because "I said so" without any technical data to back it up |
If you dilute any oil with diesel, it'll affect the viscosity. Lots of town driving will accelerate the dilution process, motorway driving will extend it
The "UK's premier Range Rover Specialist" wants you to have your oil changed every 4k miles. Thats a great business plan ![]() ![]() While still using 5w30 Last edited by Disco_Mikey on Thu Feb 08 2024 6:49pm. Edited 1 time in total |
Weird, I got oil analysis done on my last 5w30 C1 change with 15,000km/1 year on it and it had <0.5% fuel in it with a little lower than normal viscosity. From observation my car does a DPF regen about once a month and it doesn’t take very long usually. My driving is a mix of town and highway with a little freeway here and there. The oil analysis did show my copper levels were above normal and may have been due to some work I did during that oil change, but not so much they said to worry. Will see what they say on the next report and if the copper levels are still elevated.
LR time reckoned it was poor oil flow to the bearing shells due to a poor design
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5086 ![]() ![]() ![]() |
So the answer to all the SDV6 engine issues is as simple as change to 10w40 oil, I'm really surprised L/R's r&d after 15 years never thought of that, when all they had to do was look to the online " armchair experts". |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9082 ![]() ![]() ![]() |
150k+ miles here. Serviced as book by an indie using LR mandated oils.
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 139 ![]() ![]() |
It could also be poor assembly work. Some bolts under-torqued, some unevenly torqued etc. There is also the issue of bolt quality, consistency between individual bolts, consistency between bolt batches. Of course, there are possible issues with the engine components manufacturing process. Too many variables, any one or more of which may cause engine failure. Perhaps, it's about time we got the NTSB involved. ![]() |
If we get the NTSB involved, they'll say that Boeing did a perfectly good job designing the vehicle and there's nothing to see here... |
On the other hand, they (NTSB) might tell us there are a couple of missing big-end bolts. |
One question I have is: do Citroen and Jaguar suffer the same rate of crank failures when running the Ford/PSA Lion engine?
5 car brands use the 2.7L engine AFAIK. Jaguar, Land Rover, Ford, Citroen and Peugeot. Who builds these engines?
I am under the impression that Ford built some (for Ford, JLR) and PSA built some (for Citroen and Peugeot). But that's only what I read somewhere so it could be totally wrong. 2012 SDV6 - it's missing a couple of cylinders
