![]() | Home > Maintenance & Modifications > L320 under tray bolts |
Cpt Jack Sparrow Member Since: 07 Sep 2016 Location: Cardiff Posts: 182 ![]() ![]() ![]() |
Hi all. Tried a search but to no avail.
Tried heat...
Have you tried soaking them in penetrating oil for a couple of day's, then use a good six sided socket and impact wrench. Buy a tin of copper slip as well when they go back.
Thanks Col, that's my next approach.... |
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167 ![]() ![]() ![]() |
Eh up
Ah yes now you say it, I remember your thread... |
Thread revival and update.
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 274 ![]() ![]() |
For damaged hex heads, as a last resort, if you have a Dremel, get some carbide tips, its fairly easy to then re-cut a hex, the next size down. The next size down may well be Imperial/AF.
Well I finally gave in on this job and put the Car into Protec 4x4 just outside Cardiff
Eh up,
