![]() | Home > Technical > suspension fault |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5138
Ensure park brake off when u do it. Ideally out
| mark8815 Member Since: 12 Nov 2023 Location: West Yorkshire Posts: 22
Great thankyou. Didnt realise the park brake needed to be off, on mine it works both on and off. Thanks again |
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
It will work with the park brake selected, but if you watch the wheels when you lower to access height, you will see that there is a slight change in wheelbase - the front wheels turn ever so slightly if the EPB is applied. That rotation is then applying torque to any part of the drivetrain that is restrained. No idea if that includes the gearbox in park but knocking it in to access height as you slow to a stop means that everything is free to move as it settles.
