| RRSPORT.CO.UK | ||
|  | Home > Technical > Access to gearbox T40 bolts |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | The gearbox fits many manufactures and isn't designed to be serviced in situ, or serviced at all!
|  Mon Nov 20 2023 11:56am |
| ShouldHaveStuckWithAudi Member Since: 20 Nov 2023 Location: Godstone Posts: 39      | Thanks Andy. Will check the bolt lengths but think the replacements are all the same M6's - have now checked and all the same. Bolts going back in were much easier than the T40's coming out - got a torque wrench on most of them except those behind the cross members.
|  Wed Nov 22 2023 10:21pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | Car in high suspension. Axel stands under it.
|  Wed Nov 22 2023 10:36pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | The cross member is supposed to be taken off for some of the access requirements around the transmission, that's why it's in the way. 2012 SDV6 - it's missing a couple of cylinders
|  Wed Nov 22 2023 11:13pm |
| ShouldHaveStuckWithAudi Member Since: 20 Nov 2023 Location: Godstone Posts: 39      | Thanks but not touching/removing anything i don't have to on this thing - likely to break it or me.
|  Thu Nov 23 2023 10:37am |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Workshop manual here if you're going to be doing stuff yourself on your RRS:  https://www.mediafire.com/file/yunzrqm47py4pww/RRSL320WSM2006.pdf 2012 SDV6 - it's missing a couple of cylinders
|  Fri Nov 24 2023 10:34am |
| ShouldHaveStuckWithAudi Member Since: 20 Nov 2023 Location: Godstone Posts: 39      | @Andy - thanks again - good tip re the access height - not something i've had before in road-going audi's.
|  Fri Nov 24 2023 12:22pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | If doesn't, purchase 2 tubes of Dr. Tranny or shudder guard additive. | ||
|  Fri Nov 24 2023 3:46pm |
| Posting Rules
