![]() | Home > Technical > Access to gearbox T40 bolts |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145
The gearbox fits many manufactures and isn't designed to be serviced in situ, or serviced at all!
| ShouldHaveStuckWithAudi Member Since: 20 Nov 2023 Location: Godstone Posts: 39
Thanks Andy. Will check the bolt lengths but think the replacements are all the same M6's - have now checked and all the same. Bolts going back in were much easier than the T40's coming out - got a torque wrench on most of them except those behind the cross members.
Car in high suspension. Axel stands under it.
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
The cross member is supposed to be taken off for some of the access requirements around the transmission, that's why it's in the way. 2012 SDV6 - it's missing a couple of cylinders
Thanks but not touching/removing anything i don't have to on this thing - likely to break it or me.
Workshop manual here if you're going to be doing stuff yourself on your RRS: https://www.mediafire.com/file/yunzrqm47py4pww/RRSL320WSM2006.pdf 2012 SDV6 - it's missing a couple of cylinders
@Andy - thanks again - good tip re the access height - not something i've had before in road-going audi's.
If doesn't, purchase 2 tubes of Dr. Tranny or shudder guard additive. |
| All times are GMT |
