![]() | Home > Faults & Fixes > Fluctuating revs |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1197 ![]() ![]() ![]() |
Like you say Dr Tranny is not a fix only a sticking plaster option, but if you're only keeping it 6 months. Equally something may fail if you are carrying a mechanical fault. Someone else will be along with additional info...... 2006 2.7 TDV6 HSE in Cairns Blue. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4625 ![]() ![]() ![]() |
don't need to drain oil
Hullrrs Member Since: 29 Aug 2023 Location: Hull Yorkshire Posts: 25 ![]() ![]() ![]() |
Thank you
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8644 ![]() ![]() ![]() |
It is very much a sticking plaster remedy and you might find it needs a repeat application depending on how much you drive it and how much the clutch plates are contaminated. But if it's a "6 months and scrap it" car then it would seem a worthwhile thing to try. 2012 SDV6 - it's missing a couple of cylinders
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1530 ![]() ![]() ![]() |
I had the start of Torque converter trouble - symptom was vibration. My indie added Dr Tranny and that was Jan 2021 and 25,000 miles ago. All still good... 🤞
Ordered 2 today hopefully will be here this weekend so will give it a go nothing to loose
Don’t touch the fluid. Wear gloves.
Wow doesn’t say that on the reviews I will be extra careful thank you |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 363 ![]() ![]() ![]() |
Yeah, but probably only in the state of California, where everything causes cancer and needs a prop 65 label on it. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Well went through the steps today and tied the dr tranny.
Site Copyright © 2005-2023 Futuranet Ltd & Martin Lewis
