Home > Faults & Fixes > Fluctuating revs
Hullrrs
England 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Fluctuating revs
Evening everyone looking for some help and advice
My 2.7 rrs 2008/9 has developed an annoying problem.
When driving the revs have started fluctuating jumping up and down.
Gears all change fine and smooth and cruses along fine just the rev needle fluctuates.
Reading on here a lot of people say try dr tranny see if that helps
Not sure how to put it in on the drive and should I take any oil out first?
I know this would only be a temp fix but can’t really justify a £1000+ bill on a car I only paid £2.5k for
I’ve only got this as a stop gap till I get a newer sport so need to keep it going for about 6 months
Any advice would be greatly appreciated
Many thanks
Post #637432 Sun Nov 19 2023 7:57pm
Stevepd
Like you say Dr Tranny is not a fix only a sticking plaster option, but if you're only keeping it 6 months. Equally something may fail if you are carrying a mechanical fault. Someone else will be along with additional info...... 2006 2.7 TDV6 HSE in Cairns Blue.
Post #637434 Sun Nov 19 2023 8:07pm
don't need to drain oil
here is how to add to a diesel car:
https://www.disco3.co.uk/forum/topic89429-135.html
Post #637435 Sun Nov 19 2023 8:32pm
Hullrrs
Thank you
That’s the type of write up I like nice and simple I will give it a go at weekend
Have either of you tried this product?
Post #637438 Sun Nov 19 2023 9:36pm
It is very much a sticking plaster remedy and you might find it needs a repeat application depending on how much you drive it and how much the clutch plates are contaminated. But if it's a "6 months and scrap it" car then it would seem a worthwhile thing to try. 2012 SDV6 - it's missing a couple of cylinders
Post #637439 Sun Nov 19 2023 10:08pm
Eaters
I had the start of Torque converter trouble - symptom was vibration. My indie added Dr Tranny and that was Jan 2021 and 25,000 miles ago. All still good... 🤞
So, if that's your issue, it should be good for 6 months. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #637454 Mon Nov 20 2023 12:54pm
Hullrrs
Ordered 2 today hopefully will be here this weekend so will give it a go nothing to loose
I will update with results see if it can help anyone else on here
Post #637463 Mon Nov 20 2023 10:18pm
Don’t touch the fluid. Wear gloves.
It can cause cancer
Post #637466 Mon Nov 20 2023 10:53pm
Hullrrs
Wow doesn’t say that on the reviews I will be extra careful thank you
Post #637528 Wed Nov 22 2023 8:30pm
NoExpert
Yeah, but probably only in the state of California, where everything causes cancer and needs a prop 65 label on it. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #637531 Wed Nov 22 2023 9:14pm
Hullrrs
Well went through the steps today and tied the dr tranny.
Took about 5 mins in total and wow what an instant difference.
Did a 300 mile trip round today never missed a beat and no fluctuating revs
I will see how long it lasts and update on here
Thanks for your help everyone
Post #637599 Sat Nov 25 2023 5:09pm
Eaters
Thumbs Up Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #637608 Sat Nov 25 2023 10:46pm
ShouldHaveStuckWithAudi
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Just to add here, been having the same fluctuating revs which i understand means the TC is on the way out. Added Dr Tranny at the weekend and could literally notice the difference within 1mile...i only do the school run and haven't noticed the revs at all within the first couple of miles. I was another sceptic but it really is a miracle band-aid (plaster for Brits).
Only think i'll note, when putting the stuff in from the radiator method, i didn't draw enough out so hit problems - strongly suggest getting a 'bladder syringe' (marry a Dr and she will 'borrow' one for you) and draw out at least 60ml per tube you're putting in. I've only used one so far as doesn't seem to need the second that was recommended.
Post #639908 Thu Feb 22 2024 11:46pm
