![]() | Home > Technical > Suspension problem |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 215 ![]() ![]() ![]() |
4x4 Airseals do a kit for changing seals and drier beads. Just done myself on mine , need to determine make of compressor. |
I have had the pressure faults since putting in new ace pipes, but have disappeared since a manual bleed.
83series3 Member Since: 19 Sep 2021 Location: South East Kent Posts: 50 ![]() ![]() ![]() |
Thanks, Alfapat. Yes, it is possible for air to be in the system - I followed the Atlantic British procedure from YouTube, which included pulling the pipes off at the roll bar, but only did it for the front pipe.
The way I bled my system , not truly tested yet as I have developed another problem which Ill post.
skullbyka Member Since: 10 Mar 2023 Location: London Posts: 14 ![]() ![]() ![]() |
Having owned a Discovery and now a RRS I am sick of hearing and being expected to put up with cars that are not fit for purpose and which the manufacturer seems unphased by. I will return to Jeep Ownership - from whom I had 10 plus years of non-problematic Ownership before switching to Landrover which are incapable of more than a month at a time of full functionality. I am the darkness before the storm |
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1907 ![]() ![]() |
You are basing this after owning a 18 year old car, does it have a full known maintenance history?
Good point , I was about to consider this reply when I went back in here.
[quote="83series3"]
So, I've also been having this problem for a month or so..... mainly on slow speed left handers (eg, turning into a side road) the Dynamic Response light illuminates, flashes red, and tells me to stop. If I don't, it goes from flashing to solid red. If I stop / restart engine, it goes away until the next episode. I have read the fault codes with an iCarSoft i930, which gives me 2 fault codes : (1) C1B11 Pressure Control Valve, and (2) C1119 Hydraulic Pressure. I have changed the DRS filter, pulled the pipe from the front ARB to drain out more fluid, and have topped up with the correct grade PAS fluid. There are no signs of (current) fluid leaks that I can see. A couple of things spring to mind: 1) Is the iCarSoft i930 sub-par, as from reading other posts, I suspect there is a further layer of 'sub-error' that it is unable to read? 2) Does the order in which the errors are displayed correlate to the order in which an error is detected, eg, a hydraulic pressure error is a consequence of the pressure control valve error? I have had a bit of a play with using the live data streams for the roll control module, but there are 37 of the blighters, so not really sure where to start with that .... I did run the data stream for the pump pressure, which got to 4 somethings (13 year old daughter was monitoring whilst I drove, so that's all the info she gave me!!), and dropped to 0 once the red light came on and the system shut itself off. So, any pointers would be most welcome .... and also, whether I'm doing any damage running the car once the system has shut itself down?[/quote Having gone back to this thread and trying to sole my issue with dynamic active roll control , I thought I would trace the fault . It is at present and pretty consistant an Electrical failure : C1B11-1D Presure control valve - General Electrical Failure - Circuit current out of range . I take it that its wiring , but is there a way of detecting pressure on the valve with GAP 11? Did the above author 83series3 get any resolve please. Cheers Pat |
Hi Pat,
C1B11-1D(AF) Pressure Control valve-General Electrical Failure-circuit current out of range
I have wondered about getting a donor valve block and having a poke about as well - your fault code suggests a fault with the PCV circuit …. Which I presume is some magic in the block somewhere?
I have replaced all four front pipes , they are secured to the blocks, by a clamp on all for pipes . The only way to remove them is to loosen all fixtures allowing the BLOCK to release and free off the pipes. The pipes are into to the block with a sealed insert. I'm hoping gentlemen of salvage might be able to supply a valve block with components. |
Mccolganm4 Member Since: 14 May 2021 Location: Dundee Posts: 68 ![]() ![]() ![]() |
Think I have a valve block in the shed if you want it. Bought as a spare for my l320 but never used. It is second hand but has had all the seals replaced and the filter replaced. Has a pressure sensor installed. Give me a shout and I'll get some pictures |
Sent PM I think? Cheers |
