Home > Maintenance & Modifications > L320 rear anti roll bar ARB loud thump video
Max100
Northern Ireland
Discovered today the source of a very loud tump from the rear of my sport when crashing over potholes. The arb bush has not enough wear to let the bar move up/down or back and forth. It does however have enough wear to let the bar slide in and out causing a very loud thump. I was chasing this thump for weeks with a large pry bar testing all the bushes and found them to be all ok. I even wrapped harmonic dampers in foam to see if it was the cause. I’m sure you guys already know to check this but thought it might be of help.
Post #636654 Tue Oct 17 2023 6:01pm
The bar has to have some lateral movement as it's a spiral groove that counters the roll torque. So there must be some lateral movement when the bar is operating. 2012 SDV6 - it's missing a couple of cylinders
Post #636661 Tue Oct 17 2023 8:38pm
Max100
Northern Ireland
I have a small video I took showing how much play but can’t figure out how to post it here
Post #636691 Wed Oct 18 2023 8:43pm
TheWojtek
Upload to youtube and post link here, the forum will format it nicely to view inline. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #636692 Wed Oct 18 2023 9:16pm
Max100
Northern Ireland
Hopefully this works https://youtube.com/shorts/usZWAOhfPIk?feature=shared
I have new bushes on order and will post the results when fitted.
Post #636698 Thu Oct 19 2023 3:04pm
Max100
Northern Ireland
Post #636706 Thu Oct 19 2023 7:42pm
