![]() | Home > Technical > Help Electrical problem |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 403 ![]() ![]() ![]() |
My deployable tow bar also doesn’t work. When I press the on button it just lights up red and bleeps. I’m going to disconnect the battery and leave for half an hour then reconnect and hope that a system reset will fix everything. I’m not feeling confident though…… |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 366 ![]() ![]() ![]() |
The AA men are the mechanic scum of the earth . I have "worked " with quite a few.
The car has been on charge for a week on a CTEC charger and according to that it says battery is ok and has the green light on it. When I open the door the battery low please start engine sign comes up on the dash board. |
What is the battery voltage when the car says low battery?
Not too sure but I can check. What should the voltage be? Do I need to check at the battery terminals or can it be done at the terminals under the bonnet? |
On the battery would be best ...measure and let me know Always listen to old people or when they die you will live on in ignorance.
No problem I’ll do this shortly. Thanks for your help.👍 |
So just been out to the car and now there are no low battery warning on the dash boot lid opens and shut with remote and the tow bar working as it should . I did drive the car yesterday when the AA man had gone just to make sure everything was ok. Should I still check the battery voltage? This problem started after I washed the car. I have a CTEC connector fixed to the charging terminals under the bonnet that comes out under the windscreen scuttle. There is a very slim chance this could have got wet. Could this have caused all my electrical problems ? |
Just checked the voltage at the battery. It’s 13.1v. Is this good? |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1767 ![]() ![]() |
Good idea I’ll do that. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4823 ![]() ![]() ![]() |
Did the AA man plug the computer in and tell the car it has had a new battery fitted ? |
At 6 minutes it tells you how to reset. There are 2 types of reset. No red lights mentioned though |
He didn’t fit a new battery as there was nothing wrong with it. He had his test equipment attached to the battery and he did all sorts of tests like starting car , putting heated seats on etc and all was ok according to his test meter. |
