Home > Technical > Help Electrical problem
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
So on a previous thread I told you my car died on the drive. Assumed it was the battery so had the aa out today to fit one. Car started up first time and battery and everything else tested and all good. Aa man said no need to change battery as there is nothing wrong with it. Just been on an hours drive and turned car off. It bleeps and says battery low please start engine. Also the boot lid wont open when the button pressed but it will close ok. Everything else seems ok with the car and drives as it should with no warning lights etc. Any ideas?
Post #635852 Sat Sep 16 2023 12:22pm
Johnrrs
My deployable tow bar also doesn’t work. When I press the on button it just lights up red and bleeps. I’m going to disconnect the battery and leave for half an hour then reconnect and hope that a system reset will fix everything. I’m not feeling confident though……
Post #635875 Sun Sep 17 2023 7:49am
Pistnbroke
The AA men are the mechanic scum of the earth . I have "worked " with quite a few.
The battery will not re charge from discharged state on the car. Common old wife's tale.
The voltage is not high enough . You want 12 -24 hrs on a home charger and if its any good you will be OK Always listen to old people or when they die you will live on in ignorance.
Post #635876 Sun Sep 17 2023 7:50am
Johnrrs
The car has been on charge for a week on a CTEC charger and according to that it says battery is ok and has the green light on it. When I open the door the battery low please start engine sign comes up on the dash board.
Post #635878 Sun Sep 17 2023 8:00am
Pistnbroke
What is the battery voltage when the car says low battery?
Your "Charger " is a battery maintainer not a charger. The charger needs to get it up to 15v for it to be fully charged and to remove sulphate . If the battery is over 4 years old scrap it and get the cheapest you can find on ebay. Always listen to old people or when they die you will live on in ignorance.
Post #635879 Sun Sep 17 2023 8:06am
Johnrrs
Not too sure but I can check. What should the voltage be? Do I need to check at the battery terminals or can it be done at the terminals under the bonnet?
Post #635880 Sun Sep 17 2023 8:09am
Pistnbroke
On the battery would be best ...measure and let me know Always listen to old people or when they die you will live on in ignorance.
Post #635881 Sun Sep 17 2023 8:20am
Johnrrs
No problem I’ll do this shortly. Thanks for your help.👍
Post #635882 Sun Sep 17 2023 8:27am
Johnrrs
So just been out to the car and now there are no low battery warning on the dash boot lid opens and shut with remote and the tow bar working as it should . I did drive the car yesterday when the AA man had gone just to make sure everything was ok. Should I still check the battery voltage? This problem started after I washed the car. I have a CTEC connector fixed to the charging terminals under the bonnet that comes out under the windscreen scuttle. There is a very slim chance this could have got wet. Could this have caused all my electrical problems ?
Post #635884 Sun Sep 17 2023 8:50am
Johnrrs
Just checked the voltage at the battery. It’s 13.1v. Is this good?
Post #635887 Sun Sep 17 2023 9:27am
jimbg
You need to check when it has been left for a while, at least overnight. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #635888 Sun Sep 17 2023 10:01am
Johnrrs
Good idea I’ll do that.
Post #635889 Sun Sep 17 2023 10:15am
Did the AA man plug the computer in and tell the car it has had a new battery fitted ?
Post #635892 Sun Sep 17 2023 10:46am
At 6 minutes it tells you how to reset.
There are 2 types of reset. No red lights mentioned though
Post #635893 Sun Sep 17 2023 10:55am
Johnrrs
He didn’t fit a new battery as there was nothing wrong with it. He had his test equipment attached to the battery and he did all sorts of tests like starting car , putting heated seats on etc and all was ok according to his test meter.
Post #635898 Sun Sep 17 2023 3:03pm
