![]() | Home > General > Hi all :) - My 2013 L320 thread |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5120 ![]() ![]() ![]() |
The 019 is 353mm long which fits mine with no issues albeit mine is a AGM with a different code it is still the same length as the 019, the 020 is 393 within a mil or two.
Bertbuckie Member Since: 04 May 2021 Location: Scotland Posts: 274 ![]() ![]() ![]() |
Aye I can confirm the Bosch 20 doesn’t fit |
Well, the handbrakes gone mad…. Locked on and had to pull cable, the rear ace is leaking and I had gearbox oil changed and it now says gearbox error! Ohh, and drivers door lock modules done.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4517 ![]() ![]() ![]() |
Dealers are only after the quick, easy money. Servicing/brakes etc |
You’re a knowledgeable man, very infact, but that’s not looking after customers except pcp ones. Terrible service imho. |
Finally got the car back. Amazing polish lad who’s ex Land Rover sorted her.
Thank you |
RobBarwell Member Since: 08 Dec 2023 Location: Derbyshire Posts: 4 ![]() ![]() |
As in a V8 petrol or TDV8? |
Tdv8… but only as I couldn’t afford to run the petrol one haha |
Ive looked at a few TDV8's. the only issue I have is that I have a private plate. (Given to me on a birthday)...Sounds silly but it can only go on a 2013 or later. However the TDV8 are so much cheaper than the later SDV6 so would have a few more funds to fix it if it breaks |
IMO the v8's are a lot more reliable than the SDV6 I have. |
Quick question to all. I have a LATE 2013 L320 as seen.
I thought the emergency Park Brake release was just a bowden cable with a loop in the end of it which you just pull, and if needed use the hook end of the jack handle for extra leverage if needed supposed to take 45lbf to release it |
Yeah col that’s what I’ve been told, that I pulled the wrong thing but it defo removed my jammed handbrake and allowed me to drive. Very strange, unless it does both? One lad called Land Rover and was told in the 2012 model there isn’t a release cable, and you must release at the rear brakes? Seems to be some conflicting information. If it is for the transmission on mine, I don’t understand why it worked straight away. The only thing I could think of was it was just at changeover so parts had been altered perhaps. A strange one indeed. I notice on the 405 it’s in the manual as epb emergency release, but later says transmission also. |
