![]() | Home > General > Front Brake Refurbish |
Do you ever stop? |
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167 ![]() ![]() ![]() |
Eh up Stevepd
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 516 ![]() ![]() ![]() |
I refurbed some Brembo four piston calipers not too long ago and put them on my 2011.
Eh up NoExpert
What’s to screw up the EPB? Just need to get it into service mode (dismount I think it is) so the EPB is retracted, then go for it. And that’s only if you plan to remove the rotors. It’s still drum/rotor so not affecting doing the regular disc brakes. Plus the parking brake shoes could probably use an adjustment.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
You probably want to do preventative maintenance on the epb.
Eh up NoExpert
If you get Brembo 4 piston calipers from 2005-2009 they’re a straight swap less the wear sensor and pads (obviously). If you get Brembo 6 piston calipers from 2010+ you need new rotors as well and the dust shields will barely fit, sort of.
Eh up all,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
It is a range rover so probably having a fit of the miseries having been parked for a few day's, |
Mine did the same. Think it looks for the switch signal and pressure. With everything being changed it may not initially see the pressure side. No issue since, just know it may occur when you do brakes.
Eh up
