Home > General > Front Brake Refurbish
TTR
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Eh up all,
Well in between jobs elected to change front discs n pads ( big shout to Bodsys Brake Bible ) Thumbs Up
I’m no lightweight but FM Censored my caliper bolts must have been put on by a Silverback Shocked
I needed a breaker bar and a metre scaff pole I keep to get enough leverage 🥵
To be fair discs n pads were about 50% they weren’t bad but picked up Febi discs and pads for £130.00 which I thought was ok and for the effort worth replacing
Decided to do a clean up of all components, stripped fronts back including dust shields
Did a quick spray of dust shield with upon gravi guard.
Dremel on caliper carrier and calipers themselves, vht black gloss enamel on both
Looks a lot better now I think.
Post #635185 Sun Aug 20 2023 6:30pm
Stevepd
Do you ever stop? Laughing 2006 2.7 TDV6 HSE in Cairns Blue.
Post #635191 Mon Aug 21 2023 5:36am
TTR
Eh up Stevepd
Thumbs Up Low boredom threshold Rolling with laughter
Post #635192 Mon Aug 21 2023 6:08am
NoExpert
I refurbed some Brembo four piston calipers not too long ago and put them on my 2011.
 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #635197 Mon Aug 21 2023 8:52am
TTR
Eh up NoExpert
Quality job on them, I am looking at upgrades but cash is king and I ain’t got any 🤨🤣
Was tempted to do my callipers red but given condition, opted for gloss black as a quick ish refurb
Really need to do backs next bit this epb is putting me off🙁
The horror stories I’m reading are making me think can I do this.
I’m happy with spanner’s all day long , but I don’t want to bu88er the epb up.
More reading required and no doubt question on here - it’s an October job .
Post #635199 Mon Aug 21 2023 9:33am
NoExpert
What’s to screw up the EPB? Just need to get it into service mode (dismount I think it is) so the EPB is retracted, then go for it. And that’s only if you plan to remove the rotors. It’s still drum/rotor so not affecting doing the regular disc brakes. Plus the parking brake shoes could probably use an adjustment.
The four piston Brembos tend to be cheap (mine were free) and are a straight bolt on for the standard 10-13 brakes. Only other part I changed was getting a 10-13 brake pad wear sensor for the Brembo calipers.
Also did my rears:
Post #635224 Tue Aug 22 2023 1:20pm
You probably want to do preventative maintenance on the epb.
Make sure the shoe lever is free to move.
Adjust them to spec
Post #635232 Tue Aug 22 2023 6:59pm
TTR
Eh up NoExpert
Thanks for heads up on the epb, I’m just being cautious used to the BMW set up and that looks very similar Very Happy
Planning on pads and discs changing plus a tidy up on the calipers.
Will keep a look out for the brembos- never knew it was a straight bolt on though - that’s good to know Thumbs Up
Must admit fancy the red calipers on mine
Need to read more on this so thanks for the pointers
Just finished off drivers side tonight, bolting back together tomorrow after flatting the rear bumper back.
Cheers Thumbs Up
Post #635233 Tue Aug 22 2023 7:55pm
NoExpert
If you get Brembo 4 piston calipers from 2005-2009 they’re a straight swap less the wear sensor and pads (obviously). If you get Brembo 6 piston calipers from 2010+ you need new rotors as well and the dust shields will barely fit, sort of.
Since I could get the Brembo 4 piston calipers free (needed to be refurbed/rebuilt) this was a much more economical choice for me. The red is a nice little splash of color on my Fuji White RRS with gloss black wheels. One thing I particularly like about the Brembos is they look massive behind the wheels. Yellow doesn’t look too bad either. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #635272 Wed Aug 23 2023 4:10pm
TTR
Eh up all,
I’ve had a daft question, I changed pads n discs a week or so ago.
After I finished I did not start the car just pumped the foot brake to centre the pads to the discs and left it.
Not started car at all since as been spraying my bumper, finished that and rebuilt it tonight.
After making sure everything thing was re connected jumped in car with a smile Very Happy
Tried to start car as normal- all lights on - check complete but would not start Sad
Jumped out locked / opened and repeated - same result all check lights on - but not start Shocked
Took a breath - thought about it - tried again and message came up press foot brake to start. (I was doing)
So applied more pressure to brake and started - 😅
Let it run a while - moved popped into reverse and it would not move Big Cry Big Cry - seemed as if brake was on, Applied EPB - disengaged EPB all normal. Put in drive and applied more throttle- car moved and was if front brakes had stuck on. Exclamation
Struck into reverse and all good , drove it a few metres in out of garage and brakes fine, no warning lights at all.
Switched off and tried again to start - all started as normal Very Happy
What did I do wrong.
Only thing I can think of is when I centred the brakes (with the engine of ) and just pushed the brake pedal down it screwed with the electronics and it could not sense or register that my foot was on the foot brake to start .
I want to avoid a repeat of this excitement Censored when I do the rears
I’m hoping it’s back to normal will fully test drive tomorrow when bumper is re fitted completely
Any thoughts or advice welcome - my ar53 fell out when it happened Rolling with laughter
Post #635578 Tue Sep 05 2023 8:39pm
It is a range rover so probably having a fit of the miseries having been parked for a few day's, Laughing perhaps things had got a bit damp if parked up outside for a few days.
Post #635582 Tue Sep 05 2023 9:49pm
NoExpert
Mine did the same. Think it looks for the switch signal and pressure. With everything being changed it may not initially see the pressure side. No issue since, just know it may occur when you do brakes.
The sticking can happen from sitting, had this as well in multiple cars. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #635583 Wed Sep 06 2023 5:08am
TTR
Eh up
Col - I hope it’s just thrown a wobble - given it’s been inside doubt it’s damp but ....appears ok
NoExpert - That’s a massive relief I thought I’d really cocked it up Whistle
I finished bumper fittings but too dark for pictures will post tomorrow and took it for a spin, started fine, importantly stopped ok Thumbs Up
No hissy fits to report "................yet, in those imports words its thinking “I’ll be back” Rolling with laughter
Thanks both
Next jobs are rears and whatever else anyone recommends on a 12 plate 100k SDV6 - ( that leaves a wide platform for comments)
Post #635608 Wed Sep 06 2023 8:28pm
