Home > Off Topic > Computer Tech support - anyone?
Page 2 of 3 <123>
aljo
i blame alexander graham bell its his fault Twisted Evil
Post #63233 Sun Oct 22 2006 10:13pm
Wasn't he a British Olympic Skiier? 2005 Zambezi TDV6 - Gone but not forgotten
Post #63235 Sun Oct 22 2006 10:14pm
aljo
must have invented the telephone in his spare time then Rolling Eyes
Post #63237 Sun Oct 22 2006 10:15pm
Kaine, let me have a look into this for you tomorrow when someone's paying me to do nothing else Wink
Post #63268 Sun Oct 22 2006 10:45pm
Cheers - much appreciated - just make sure you bill them for the extra time Wink
Post #63270 Sun Oct 22 2006 10:46pm
Kaine, I found this... could you run through the registry and file system pointers that this document talks about please?
http://www.microsoft.com/technet/prodtechn...x?mfr=true
Don't worry about this appearing to be for Win2k, these policy components are identical.
Post #63351 Mon Oct 23 2006 11:54am
thanks very much - will try it out a little later
Post #63394 Mon Oct 23 2006 2:04pm
When ever i try to install the drivers for the sound card the pc restarts half way through!
Anyone know what maybe up with this ?? RRS TDV6 Gone but still around
Post #63398 Mon Oct 23 2006 2:10pm
Try later set of drivers?
If the soundcard is a PCI card, move it to another slot and retry?
Update the BIOS on the PC?
Post #63432 Mon Oct 23 2006 3:11pm
no good - doesn't even exist in my registry so should be set to 0 and hence allow me to delete
have removed the only user on the system also - leaving just the admin and guest user - same problem exists, although thought it would as I was logged in as administrator anyway
definetely an odd one this
Post #63481 Mon Oct 23 2006 11:02pm
Hmm..
Did you also try the bit about the write permission on the Pbk folder?
Post #63483 Mon Oct 23 2006 11:09pm
shmoogle wrote:
Hmm..
erm - missed that bit - what have I missed?
Post #63484 Mon Oct 23 2006 11:17pm
That article mentioned something about the permissions on this folder:
C:\Documents and Settings\All Users\Application Data\Microsoft\Network\Connections\Pbk
In fact, I've just been playing here with that directory too and I think I can replicate your problem. Seems to centre around the above folder and a file called rasphone.pbk which holds your dialup connections. From what I can see, this file gets read at logon and presented in your Network Connections folder. If you don't have the right permissions to it (either on the file or the containing folder), you can either not delete existing connections (your problem) or not create new connections.
I can replicate the problem by doing this:
- After logging on to XP rename the rasphone.pbk to something else (rasphone.old)
- Try removing a connection - doesn't work (no error, just doesn't work)
- Restore original filename (rasphone.pbk)
- Try removing a connection - removes as expected
So I'm sure the problem centres around there somehow.
Let me know how it goes mate.
Post #63485 Mon Oct 23 2006 11:29pm
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up
done!!!
the file was there and permissions looked ok - so out of interest I changed the name as you did - tried to delete the dialup - nothing - so renamed it back and tried again - it worked
not sure exactly why renaming it and naming it back made the difference but it did
Thanks very much indeed for taking the time to look into this for me
Post #63486 Mon Oct 23 2006 11:47pm
Where should Shmoogle send the invoice? 2005 Zambezi TDV6 - Gone but not forgotten
Post #63490 Tue Oct 24 2006 8:11am
Page 2 of 3 <123>
