![]() | Home > Off Topic > Computer Tech support - anyone? |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 ![]() ![]() ![]() |
i blame alexander graham bell its his fault |
Wasn't he a British Olympic Skiier? 2005 Zambezi TDV6 - Gone but not forgotten
must have invented the telephone in his spare time then ![]() ![]() |
Kaine, let me have a look into this for you tomorrow when someone's paying me to do nothing else |
Kaine Member Since: 27 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
Cheers - much appreciated - just make sure you bill them for the extra time ![]() |
Kaine, I found this... could you run through the registry and file system pointers that this document talks about please?
thanks very much - will try it out a little later |
When ever i try to install the drivers for the sound card the pc restarts half way through!
Try later set of drivers?
no good - doesn't even exist in my registry so should be set to 0 and hence allow me to delete have removed the only user on the system also - leaving just the admin and guest user - same problem exists, although thought it would as I was logged in as administrator anyway definetely an odd one this |
Hmm..
erm - missed that bit - what have I missed? |
That article mentioned something about the permissions on this folder:
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() done!!! the file was there and permissions looked ok - so out of interest I changed the name as you did - tried to delete the dialup - nothing - so renamed it back and tried again - it worked not sure exactly why renaming it and naming it back made the difference but it did Thanks very much indeed for taking the time to look into this for me Kaine |
Where should Shmoogle send the invoice? 2005 Zambezi TDV6 - Gone but not forgotten
