![]() | Home > General > Grumbly Car |
Sounds like a torque converter issue |
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 524
I concur with DM, definitely sounds like the torque converter is giving up the ghost. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
| Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1058
Do naughty things to a duck...
Not body off (thankfully!) but not cheap either |
We use a shop that opens the converters and rebuilds them.
My mechanic will be pleased |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
I used Bristol Transmissions for a new TC on my old TDV8. Turned out that it needed a bit more than that as the output spline was worn - they said they would only do the TC if they also did the splines in the gearbox and the transfer case (input shaft also worn). Fair enough. But you have to take the insides out of the gearbox to get to the output spline. So they ended up doing a gearbox refurb, effectively, and they put a new chain in the transfer box. That ended well up over a grand, as you might imagine. 2012 SDV6 - it's missing a couple of cylinders
Told my mate about the grumbly gearbox and he got all excited and said try Lubeguard Shutterfixx. I was a bit skeptical to start with but for a few quid worth seeing what happened. Duly turned up, popped the hose off the cooler, extracted 60ml of dirty brown (but not smelly) transmission fluid and dropped this stuff in.
We talk about "it needs a new torque converter" but it's really the lock-up clutch that causes the issue. Perhaps we need to remember that when looking at the problem. It's worth remembering that these tubes of stuff don't really solve the problem, they just delay the inevitable.
| All times are GMT |
