Home > General > 6 Pot Brembo v 6 Pot Land Rover Callipers
Page 2 of 5 <12345>
Common thing on the 5.0L S/c's with the 6 pot Brembos' both L320 & L494 L/R eventualy brought out a "Ant-Squeal" pad as they called it, which supposedly cured the problem personally don't know if it did or not even genuine Brembo pads did it,, the only thing that shut mine up was EBC Redstuff pads which you can't get any more for SUV's, have not tried Yellowstuff though.
Post #631634 Wed Mar 15 2023 12:04am
Farmer Chalk
The issue I had even with genuine Brembo pads rather than LR ones was that they rattled on the pins which if you went over an uneven road all you heard were rattle pads.. drove me mad!
Post #631636 Wed Mar 15 2023 12:14am
Forgot to mention mine was only really noticeable under relatively light braking, have to say I never noticed any pad/pin "rattle" on mine though.
Post #631637 Wed Mar 15 2023 1:14am
Disco_Mikey
We've had this. New retention kit sorted it Thumbs Up
Post #631640 Wed Mar 15 2023 5:52am
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
I do have the Ebc Yellow stuff pads fitted Col, Think its only under light breaking too, Its quiet when cold, I have not been harsh braking as yet so only been going slow so im hoping after a good run they quieten down. Will try a new retention kit if it doesn't go then Mikey, Bloody annoying are squeaking brakes.
Post #631641 Wed Mar 15 2023 6:02am
Have to admit it was a dammed annoying noise, I did fit a new retention kit when I changed to the ebc pads and discs so quite possibly that did help.
Post #631642 Wed Mar 15 2023 6:42am
Disco_Mikey
EBC pads are known to squeak while bedding in
The kit was for rattling pads
Post #631644 Wed Mar 15 2023 8:27am
In my case the only pads that didn't squeal at any point were the ebc ones, the original L/R fitted ones and the Brembo ones I tried were terrible, I am assuming the retention kit referred to and brembo pad fitting kit are the same thing.
Post #631645 Wed Mar 15 2023 8:41am
Salisburylander
2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Did you use Brembo B-Quiet brake grease or generic copper grease to lube the back of the pads? I used Mintex brake grease, Britpart DA2389 on mine and they were always silent.
Do you need EBC Yellowstuff pads for “fast street” use?
Post #631651 Wed Mar 15 2023 9:55am
jases4x4
Haha fast yellowstuff because they look cool inside the red callipers 😂 No i read alot recommend them and they were the most expensive so i presumed they were the best, Didnt want to go cheap on one the the biggest safety features. I used general copper grease for back of the pads, Thing is the nearside doesn't squeak at all so you would think both would if it was the grease not up to the job. Also its only after a few miles so its when it heats up. Im going for a longer drive today so should be able to do some more bedding in. Must say its not loud but enough to hear and bug you so it needs to go, I did read somewhere about Brembo changing the chamfered edge as it was a know fault. Think i will give it a few weeks and if not replace retaining kit and use some ceramic grease.
Post #631652 Wed Mar 15 2023 10:10am
Copper grease not recommended on alloy calipers, should be ceramic.
Post #631655 Wed Mar 15 2023 10:22am
jases4x4
Thanks Col, Looks like we may have found the issue then fingers crossed, Just ordered some mintex advanced ceramic, Will update when Jase has lost his squeal 😀
Post #631656 Wed Mar 15 2023 10:51am
Fingers crossed, they might just need a few more miles to bed in.
Post #631657 Wed Mar 15 2023 11:12am
Dave B
I use/used Hawk Ceramic pads, from Cambridge Motorsport, for both my 2010 RRS and 2011 Disco 4 (obviously fitted with 6 pot Bremos).
No squeal, no rattle, use grease only on the edges, and no dust.
If you want expensive, all of the above, plus exeptional braking, then these are the bees knees.
As they are unavailable for the rears, I use/used TRW D-Tec, ceramic content for better braking low dust, and if you want the athetics, the backing is red!
Dave 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #631660 Wed Mar 15 2023 12:24pm
jases4x4
I watched bodseys video where he states ceramic or copper grease can be used and it’s debatable which is best, So i will put the copper to the test give it another week bedding in pads, But i have ordered ceramic now so will still apply that when it comes. Wasnt bothered about aesthetics but they come yellow. Will keep Hawk in mind for next time but the miles i do it will he 10 years before they need changing.
Post #631665 Wed Mar 15 2023 1:37pm
Page 2 of 5 <12345>
