![]() | Home > Technical > 2012 Headlight dip/high beam mismatch. |
Should have this Icon come up when vehicle doing system check if AFS fitted, if fault with the system it should continually flash I think.
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
your correct col
aln101 Member Since: 28 Jan 2023 Location: Argyll Posts: 50 ![]() ![]() ![]() |
Andy. Your suggestions 1 and 2 are very wise, but rural area and unfortunately not many sports around otherwise I would have tried this already.. Heaps of L322s though ![]() Second hand headlight to compare is a good idea. Better to mess with a spare too. What's AFS? As to a garage setting lights ![]() Main beams should be set first for optimum light on the road and range. If the dips are not separate then they just have to be accepted where they end up. This is seldom a problem if the makers design them properly with the right angular difference between the two. A very slight compromise tweak is possible if required. MOT a couple of days ago. I set the dips back to where I would expect them to be on the road, the night before. Asked friendly MOT chap what the dips looked like and he said bang on. Thankyou. Mains are halfway up the trees. Someone mentioned bulbs. Haven't changed them. They both look fresh and straight, though it would only take a slight offset to seriously affect the cutoff due to the very short distance between the filament and the shield. I'll pull the headlights out again and have a longer look at the shields. Its a pity the projector assembly won't come out the access hole for a better look. Thanks to all Alan Series 3 109 Classic 2-door 101FC GS Three P38 4.6L RRS mk1 2012 |
These are the best I can do at the min. as it's 25 degrees and bright sunshine, however this is what I get with mine looking through the windscreen in the garage, car is about a metre from the garage door, obviously first picture dip, second main beam.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
Ok. So your dip beams have been reset. You are back to square/page 1.
Ok Andy.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9132 ![]() ![]() ![]() |
The halogens are termed "fill in beams" and are supposedly intended to help cover bits of the pattern that the xenons don't cover properly.
The later disco's and Jag's don't even have main beam halogens, so that's how important landrover considered they were,
Well.......
