![]() | Home > Technical > 2012 Headlight dip/high beam mismatch. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5117 ![]() ![]() ![]() |
No you can not adjust Main Beam and Dip Beam separately. Adaptive just means the beam moves to suit driving conditions i.e if turn a corner the beam moves to illuminate more of the road based on the direction you turn the steering wheel as it is in part controlled by the steering wheel movement, however I'm sure someone will be along to give you chapter and verse on the subject shortly. |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 ![]() ![]() ![]() |
Sounds like the headlight module has possibly died if they were aimed into the trees initially. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
aln101 Member Since: 28 Jan 2023 Location: Argyll Posts: 50 ![]() ![]() ![]() |
Well.....
Notyalc Member Since: 01 Aug 2022 Location: Northumberland Posts: 45 ![]() ![]() |
Land Rover always seem to have high beam pointing to the stars… |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5115 ![]() ![]() ![]() |
your not the first to complain.
The main beams are quite good once set properly. Good range and spread.
Sounds normal
Poked about a bit further.
Just had a look at a MY11 & MY13 sales brochure and adaptive lighting was a option on all variant except the 5.0L A/B which it was standard on, so you may not have it, the cornering lamps were standard on all variants, but obviously that is a different thing to the adaptive lighting.
Thanks for that Col.
Anyone know how to change the dip for driving on the right?
You don't, the design of the lens/beam pattern makes it adjustment free.
I believe it’s called a flat beam. (No kick up on one side )
Can always get 2010/2011 headlights with the switch and better light pattern. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
