![]() | Home > General > Looking to purchase a L320 TDV8 - advice needed |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5092 ![]() ![]() ![]() |
Certainly walk away from the second one that sounds like a total load of bulls**t to me. With the first one check the tyre size as some cars came with a 255/50 x 19 spare which is a compatible diameter with the 20's which would throw that gear selection therory out the window.
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
If I were to sell the car and had a puncture, I'd do everything that I possibly can to bring the car into proper shape before showing it to a prospective buyer. Come again once he sorts it out and take the car for a drive, seek another one if the transmission still works in 1-3 only. The other one is BS. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE Last edited by TheWojtek on Thu Feb 23 2023 9:52am. Edited 1 time in total |
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 231 ![]() ![]() ![]() |
Many thanks for your reply Col.
Hi, yes thats exactly what I am doing. To be fair the guy had the puncture the day before, he did call me the evening before I was veiwing to tell me what had happened, which was good of him. See whats happens Monday. Many thanks |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 432 ![]() ![]() ![]() |
This has been put into storage for the last couple of months, so mileage only a little more (less than 200 miles), and will come with a new MOT.
If it was the space saver spare which is much more common on the 2010-2013’s, then it’s a much bigger diameter than the 275/40R20’s. This is the space saver wheel/tire:
Thanks, it was one the same as this, but with a tyre fitted |
Hi Dave, many thanks, just a little bit out of my price range as I want to hold back a couple of thousand just in case, but thank you |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
First one I'd be tempted to redrive it once the tyre is sorted. If everything is well then it's ok to consider it. Obviously, if the gearbox is still wrong then walk away.
Will do, the chap is getting the tyre sorted over the weekend, thanks RRSTDV8 |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
stick with the first one after the test drive
The first chap has just called me saying he has had the tyre replaced and the gearbox is now working correctly. He knew I was concerned so thought he'd call before me going to see it again, nice of him. |
My car came with this style and size spare from the factory, black as well. ![]() Cheers Col |
Hi, I've just had another look at the RRS book by James Taylor, he mentions that with the 2010 model, a new system called Adaptive Dynamics, apparently on the supercharged model it was called active roll control.
