![]() | Home > Maintenance & Modifications > 2010 RRS 3 litre Timing Belt change |
AndyCHO Member Since: 23 Dec 2021 Location: Wodonga Posts: 125 ![]() ![]() ![]() |
Well it has come time to have the Timing Belt changed... I am not sure it has been done before so it is well overdue (Service records only show the HPFP being changed) and I have been getting some pricing...
Yes... Oil pump is fine on the 3 litre V6 and I definitely queried the Mechanic when he said it needed to have the Water Pump replaced at the same time..hence WHY I asked about it here. |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
You might be surprised.
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1070 ![]() ![]() |
I had both belts and serpentine belt changed - as well as oil pump on my 2.7 here in Canberra - I supplied parts and labour cost and other consumables was $1200 so I would say your quote is a bit high as parts are not all that expensive.
The water pump is completely separate from the timing. It’s a feel good change if it’s not leaking, otherwise it can be done on its own pretty easily. It would save a little cash to do it with the timing belt since the serpentine belt, intake and fan will be off and the coolant will be drained, but those take about 30 minutes. After that it’s three bolts, a few love taps and it’s out. Quick clean up, new pump in place, bolts back in, fan and intake back on, coolant filled, party time.
Thanks for that... I am most likely not going to change the water pump unless it is absolutely necessary.. but am leaning towards the oil pump being changed.
How many km on your vehicle - the argument about not replacing the water pump applies equally for the oil pump. if there is no issue with it now then I would leave it.
As far as I can tell in amongst it all the 2.7 and 3 litre share the same Oil Pump, as does the Jag and the Citroen.
You guys have Citroen or Peugeot over there? If so, look for part number 1001G2, it’s a genuine FoMoCo oil pump. I can get them here in Poland for about $240AUD brand new in the box. About $90AUD for a genuine water pump (1201K5).
Yep, oil pump shows up as $220 for the Citroen / Peugot item. The only water pump shoing is a Graf unit that replaces the 1201K5 and is about $80.
Well scratch that... the ones on eBay are aftermarket. OEM seem to be all around the $400 plus mark.
In that case buy from your local Ford dealer. 07MY RRS TDV6 Arctic Frost Aspen Interior |
I will be looking into that as an alternative. |
