Home > In Car Electronics > Rear Dash Cam mounting |
AndyCHO Member Since: 23 Dec 2021 Location: Wodonga Posts: 116 |
I have a new Blackvue DR750X-2CH Plus I am going to install into the 2010 L320.
Thu Feb 02 2023 12:36pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4868 |
I think the OP may have the split tailgate so little harder to hide the cables I believe. This is mine with the one piece tailgate, although I have now fitted a thinkware one.
Thu Feb 02 2023 9:50pm |
Yes, I have the split tailgate... hmm both those are very neat installs..
Fri Feb 03 2023 12:11am |
I made use of Daylight Saving tonight and started to investigate the rear camera mount... the split tailgate does make it a little more difficult, mainly with placement of the camera than anything else.
Fri Feb 03 2023 8:46am |
All finished, it ended up being a pretty easy install after all. The hardest part was feeding the rear camera cable through to the front.. and not have it showing anywhere... but a little time to make sure that when it was near an airbag it ran underneath and not over the top was well worth it.
Sun Feb 05 2023 11:13pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
So is that in the wiper zone - I have a dash cam on my rear window and did not put enough thought into it and it is outside the wiper zone. As a result in rain or when the rear window gets dirty the dash cam captures little and becomes useless. 07MY RRS TDV6
Mon Feb 06 2023 1:16am |
The camera itself is mounted on the plastic panel above the rear window but is adjustable for the view. Currently it would be approximately 50/50 in the wiper sweep but I am yet to fine tune the camera.
Mon Feb 06 2023 2:19am |
I fitted my rear cam to the actual rear window which just puts in the arc of the rear wiper, and get this view plus a ticket.
Mon Feb 06 2023 4:16am |
That is pretty much the view I am getting Col... minus Mr Plod. |
Mon Feb 06 2023 5:12am |
