Home > Maintenance & Modifications > Foam blocks at bonnet hinges
A1GSS
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Ipanema Sand
Hi folks
L320 2010.
Anyone know the part numbers for the foam blocks that are stuck to the bonnet lip adjacent to the hinges? Have googled for the number stamped into the part and come up with nothing.
They have disintegrated and need replacement. What are they for? I assume they're part of a seal. They seem to be soaking wet too so presumably there's a risk of a water trap causing corrosion. Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #630224 Wed Jan 25 2023 1:22pm
Stevepd
https://www.rrsport.co.uk/forum/topic59793.html
Mine also came off and found they were quite expensive each side. Other owners on the D3 site had them also fall off and not replace them. So I chose to follow suit and haven't noticed anything untoward. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #630226 Wed Jan 25 2023 3:08pm
A1GSS
Right thanks. Same also reported on FF site. Thinking I’ll remove both and clean up the area. Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Post #630227 Wed Jan 25 2023 3:59pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
They also have these foam bits on the L494. Mine were also soaking wet so I assume it’s some sort of seal…..Only issue is , I opened my bonnet the other week when I was something like -3 and it ripped the seals in half. Half still attached to the car and other half stuck to the underside of the bonnet. I will buy some new ones eventually but for now will try and glue them together when they eventually dry out which will probably be in the summer. Does anyone know a part number for these for the L494?
Post #630238 Wed Jan 25 2023 8:40pm
A1GSS
That’s what happened to mine! Useless. Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Post #630239 Wed Jan 25 2023 8:41pm
£40.00 each for the L320 from L/R.
Post #630246 Thu Jan 26 2023 6:59am
DrRob
L322 owners ditch them. They hold water so are potential rust promoters. Stupid Censored design * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #630251 Thu Jan 26 2023 9:56am
A1GSS
Wow. I think I’m going to follow the advice and remove them! Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Post #630253 Thu Jan 26 2023 10:05am
A1GSS
Think this is the best plan… Thanks. Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Post #630254 Thu Jan 26 2023 10:06am
Johnrrs
If you remove them where does the water go??
Post #630307 Thu Jan 26 2023 9:09pm
A1GSS
I don’t think that they have anything to do with drainage but I might be wrong. Look more like soundproofing…? Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Post #630308 Thu Jan 26 2023 9:37pm
A1GSS
New post on the subject on the FFRR forum!
https://www.fullfatrr.com/forum/topic65834.html
Weird coincidence! Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Post #630309 Thu Jan 26 2023 9:39pm
Johnrrs
Interesting……..
Post #630310 Thu Jan 26 2023 10:08pm
DrRob
On the L322 they are allegedly for noise dampening....I detected zero difference.
Who the hell puts sponge material where it can absorb water? Mental idea. * Current: 2024 D350 Defender 90 on coils!
Post #630322 Fri Jan 27 2023 9:49am
A1GSS
When the foam is new it’s waterproof. It seems to break down as it ages, and if it gets wet then freezes they get damaged when you open the bonnet.
Ref soubdproofing - I’ve also detected no noise difference since removal, I did a test drive yesterday and it was undetectable! Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Post #630323 Fri Jan 27 2023 9:57am
