![]() | Home > Maintenance & Modifications > Remapping ! |
AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 122 ![]() ![]() ![]() |
Hi
3hcp Member Since: 04 Nov 2021 Location: Devon Posts: 81 ![]() ![]() |
Yes but you just get it mapped out so it doesn’t open, same effect as blanking 2015 RRS DIESEL HYBRID |
Superb, they charging me extra £20 on top of remap to do this so yeah great stuff - thanks for advice. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9152 ![]() ![]() ![]() |
Bear in mind that the gearbox (and transfer box) is designed for given torque input and that the remap will push that over the design limit. So you also risk the gearbox. A 25% increase in power and 17% increase in torque puts the entire drivetrain under more strain and thus increases the likelihood of failure. The original RRS gearbox was different in the SC to that in the TDV6 and the 4.4V8 for this reason. Not saying don't do it - just remember that everything is affected by it, not just the engine (and your grin! ![]() Oh, and the only difference the extra power will make to the off road systems is that traction will be lost more easily because the tyres will have more grunt thrown at them. But on road, it'll make little difference except in slippery conditions. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5151 ![]() ![]() ![]() |
According to L/R the 5.0L S/C and 3.0L Diesel use the same uprated ZF 6HP28 transmission. My re-mapped 5.0L S/C has been throwing 550+ lbs/ft (750Nm) of torque measured on a Dyno through it for the last 6-7 years and nothings exploded yet, so wouldn't worry about the drivetrain to much. I would also take all those figures with a pinch of salt until I see the car measured on a Dyno.
Thanks guys, so also in your opinion once remapped would you still see that increase when sports is selected ? |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 750 ![]() ![]() ![]() |
Increase in what?
Superb, that’s what I wanted to hear
Probably more noticeable in sports mode but won’t turn it into a Ferrari.
I forgot he was on the 3.0TDV6. ![]() 2008 TDV8 - it was a labour of love and is much missed |
I do recall being told that they never fitted the first 8 speed boxes used in the later L320's to the S/C because they were not rated for the power output of the S/C, but they then uprated it for all L494 variants. However I don't really know if that is right or wrong, glad mine still has the stick shift though as not sure what I would use as a hand/armrest otherwise. |
I seem to remember hearing a similar story, Col. |
AlM Member Since: 08 Feb 2021 Location: Melbourne Posts: 53 ![]() ![]() |
Unrelated, but related… is a D300 the same engine as the D350, but with a different mapping? Does the D300 & D350 share the same model transmission/drivetrain? MY21.5 HSE 221KW D16
Hi Guys
