![]() | Home > Tips & Tricks > Side running boards |
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1903 ![]() ![]() |
AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 122 ![]() ![]() ![]() |
I guess….. |
You can always look under the car and check the brackets, never heard of one failing though 2023 P440e SE Dynamic on order -cancelled
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
I use mine all the time as long as brackets are OK
Mine are going and will need a new set next year. I noticed a rusty flap hanging down and had a look underneath. The mounting brackets are rusty but ok, whereas the underneath of the foot panel is decidedly patchy. I’ve had this set on 6 years now. 2006 2.7 TDV6 HSE in Cairns Blue. |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 223 ![]() ![]() ![]() |
Mine is a 2007 running boards fitted from new , no signs of being weakened at all. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
The side steps are decently robust and certainly up to being stood on - that's what they're for, after all. I used to have them on my TDV8 (they were on when I bought it) and they survived some off road work pretty well - went around Eastnor LRE and even though they rubbed on the sides of tracks, and over humps, they never failed.
