![]() | Home > General > 3G switch off |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 750 ![]() ![]() ![]() |
You can connect the car to your phone internet connection ("wifi" instead of "hotspot") and stay on the bleeding edge of speed or do nothing and enjoy slower connection on 2G, which will last until 2033. https://www.gov.uk/government/news/a-joint...rsificatio
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 259 ![]() ![]() |
If I understand correctly, the below can be plugged into the USB port and should provide a WiFi hotspot to which I can connect my head unit and provide continued data connection now using 4g instead of 3g?
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1921 ![]() ![]() |
Or use your phone as a hot spot?
The problem with using my phone is the hotspot turns off if not connected for a period of time, so I have to remember to turn it back on which once moving would be illegal use of the handset. MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green) |
Then use the second option? |
Yes, this model would work like that. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
