![]() | Home > Faults & Fixes > Restricted performance but no limp mode |
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 520
As you said, without the codes it could be mild to wild. Could be a loose clip on a hose, a split hose, a faulty IAP sensor, split manifold, faulty secondary turbo solenoid, loose/split vacuum line, split throttle body, bad throttle body seal, and more. Need the codes to get some direction. As a quick visual you can look for oil/soot around the inlet manifolds. Only requires removing the oil cap and top cover. The typical side for splits is the right side as you look at the engine. If there’s oil in the valley on top of the oil cooler you probably need a throttle body or at the least a seal kit. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
The only time I've ever seen an RP message on the dash, but no reduction in performance was with a faulty fuel filter housing
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677
I had this with a sdv6 & it was the flap in the throttle body sticking. Andy.
| thejack Member Since: 19 Oct 2022 Location: reggio emilia Posts: 10
Thank you all, guys. As soon as I get the iCarsoft I will be able to read all the codes to better address the root cause. In the meantime, I'm gonna check all your precious advice!
I want to update this post and thank Mikey for his huge help on that issue, which has been solved by replacing the entire fuel filter assembly. Thanks, man!!! |
| Phil2k Member Since: 18 Jun 2020 Location: Anglesey Posts: 75
I get this with mine, it comes back as water In the fuel, common issue with the fuel filter sensor. There is no water in |
