Home > General > What is this for??
Googs
Australia 2012 Range Rover Sport Supercharged Autobiography Fuji White
What is this for??
Good Morning everyone, as you know i'm new to the RRS forum, so as I've just purchased a L320 5.0 SC AB and as i was checking out the under side at the back end where the tow bar is and noticed theses weights one on each chassis rail so i'm thinking it's something to do with a removable towbar mounts. i'm hoping that someone here can enlighten me to what they are Question Question
https://www.rrsport.co.uk/gallery/albums/u...10_Pro.jpg
Post #628185 Sat Nov 12 2022 11:21pm
karlos01
I belive (don't know how true )
but The weights hanging in front of the rear bumper are to counteract resonate frequency vibrations coming from the frame of the LR3.
Post #628186 Sat Nov 12 2022 11:30pm
Indeed so - harmonic mass dampers. 2012 SDV6 - it's missing a couple of cylinders
Post #628187 Sat Nov 12 2022 11:58pm
Googs
Thanks so much for clearing that up, the mind boggles about the reason....just a little more weight to add to the heavy vehicle. Anyway it is what it is. I do believe that the body comes off the chassis with some degree of workmanship, i suppose if i was to do work on back of engine or transmission it would be a great thing to lift body off....as did the Ford F-250's in today's world.
Post #628190 Sun Nov 13 2022 12:18am
If you have a look under the car below the front wing/door post area there are some there as well only they are fixed one's.
Post #628192 Sun Nov 13 2022 12:26am
Googs
So is it only the 5.0 that has these?
Post #628195 Sun Nov 13 2022 2:06am
No there on the diesels as well, the TDV8 with four pot brembo's have some bolted on the front caliper as well although slightly smaller. Laughing
Post #628198 Sun Nov 13 2022 2:25am
