| RRSPORT.CO.UK | ||
|  | Home > General > What is this for?? |
| Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89      |
 Good Morning everyone, as you know i'm new to the RRS forum, so as I've just purchased a L320 5.0 SC AB and as i was checking out the under side at the back end where the tow bar is and noticed theses weights one on each chassis rail so i'm thinking it's something to do with a removable towbar mounts. i'm hoping that someone here can enlighten me to what they are  | ||
|  Sat Nov 12 2022 11:21pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Indeed so - harmonic mass dampers. 2012 SDV6 - it's missing a couple of cylinders
|  Sat Nov 12 2022 11:58pm |
| Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89      | Thanks so much for clearing that up, the mind boggles about the reason....just a little more weight to add to the heavy vehicle. Anyway it is what it is. I do believe that the body comes off the chassis with some degree of workmanship, i suppose if i was to do work on back of engine or transmission it would be a great thing to lift body off....as did the Ford F-250's in today's world. | ||
|  Sun Nov 13 2022 12:18am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | If you have a look under the car below the front wing/door post area there are some there as well only they are fixed one's.
|  Sun Nov 13 2022 12:26am |
| Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89      | So is it only the 5.0 that has these? | ||
|  Sun Nov 13 2022 2:06am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | No there on the diesels as well, the TDV8 with four pot brembo's have some bolted on the front caliper as well although slightly smaller.  | ||
|  Sun Nov 13 2022 2:25am |
| Posting Rules
