![]() | Home > Maintenance & Modifications > Changing Lights / Maintenance |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
The front light. Not sure which one you mean.
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 517 ![]() ![]() ![]() |
You’ll need to remove the grill (release four tabs at the top then rip it off pulling at the lower left and right corners), remove the headlight (lift/pry the two metal tabs at the top/back of the headlight straight up and then fiddle with them and the headlight to get things aligned to pull the headlight straight forward), unplug the headlight, remove the outside latching mechanism you just pulled/pried up (7mm socket and four or so screws), then remove the lower rubber cap to gain access to the cornering bulb.
